1 - 10 of 10 Posts
Tube bender, and notcher package
Only selling due to a back injury and going back to school. Here are the specs If there are any questions feel free to call me at 1-208-234-1535 ask for Bart.
Welder SOLD
Plasma SOLD
The JMR Series of manual and mechanical tube and pipe benders are precision machined units that offer heavy wall capacities.
Model 1003 Mechanical Bender
Features
  • Most Leverage of any manual bender
  • Billet Dies available in 120 and 240 degrees
  • Aluminum bronze bushings at pivot points
  • Bearing supported ratcheting mechanism
  • Anodized black finish
  • Lightweight and portable
  • Built for industrial use and yet affordable
  • Lifetime guarantee against breakage on dies
Specifications
  • Will bend .250 wall 4130 Tube
  • Follower blocks case hardened .050 min
  • All pins made from heat treated 4140
  • 2" Round Tube, 1-1/2" Square Tube,
    1-1/2" Sch 40 Pipe Capacity
Features:
  • Large capacity and low cost - The TN-100 notches 3/4" through 2" O.D. tubing at angles up to 50° in under 20 seconds. It uses commonly available bimetal hole saws costing approximately $10. A single bimetal hole saw will typically notch 3 to 5 complete cars.
  • Easy to use - The TN-100 may be mounted in a drill press or simply clamped in a vise and used with a 1/2" hand drill. The TN-100 can be laid horizontal when notching 45° angles, so the floor will not interfere with the tubing being notched.
  • Heavy duty frame - Entirely CNC machined, the frame is made from 1/2" thick 6061-T6 aluminum and its face has been milled flat. The degree increments are then machined directly into the frame so they can't wear off. An all position swivel base ensures easy setup.
  • Rigid bearing block - This is the most critical part of a hole saw style notcher. The TN-100's bearing block uses twin needle bearings and separate grease seals for maximum rigidity and reliability. A 3/4" ground and polished stainless steel shaft protects against the possibility of rust contaminating the precision bearings.
  • Strong, accurate tube cradle - As can be seen in the picture, the entire cradle and clamp assembly have been CNC machinined out of a solid steel block so the tube will be notched exactly in the middle. This eliminates the problems of tube walk in notchers that use a U-strap.
Welder and plasma are gone.
Grip Guru if who ever buys the bender does not want the notcher you will be first in line for it.
1 - 10 of 10 Posts
