1 - 17 of 17 Posts
I know, here we go again. :darn: I have a 75 ramcharger and the front driveshaft is taking a crap. I am assuming that I have 1350s, but where did that # come from? Also 1310s etc.
you should have 1310s in the front.
rear driveshaft- 1310 front, 1310/1350 crossjoint rear
frontdriveshaft- 1310 front, ??? in the CV
axles- ??(whatever is in a stock 79 chev d44)
I did and the gas tank broke. Now before I go to 2HD and break a u joint I am going to replace the front 3.
dont do the dragon ontil you replace the edeljunk carb. or youll have more problems then ujoints.
maybe you should use that steel i gave you to make a bumper and you wouldnt have a busted gastank.
isn't your toy carb'd? waiting on a chopsaw and welder and time for the bumper, but it's definately getting done before the next trip.
My suburban is carbed too. That isn't the issue your issue is your carb sucks. It floods out because of the floats. go buy a holley truck avenger or a edelbrock offroad like I have.
since we are highjacking....
the edelbrock avs doesn't do anything about the floats. they just have modified needles handle the bouncing around an offroad truck endures. i think hte truck avenger would work better since they attack hte problem of running at an angle.
just my results of research.
trev out!!
better then nothing at all....
and i think that is just a liability thing. if they said that it would run upside down stupid bastards would be flipping there shit seeing if it was true
1 - 17 of 17 Posts
