1 - 14 of 14 Posts
whats the best way to cut notches for 1 1/2" tubing? The angles would be from 0-45 degrees. Is it possible to find something for $50.0 or so?
I went and got that cheapo compound angle saw from harbor freight and put a 10" metal cutting blade on it. I think the saw was $36 and the blade was $8 or so.
Its nice as you can figure what angles you are cutting and use the degree setting on the saw.
I've done it with a Harbor freight hole saw with lousy results. My best results have been with a chop saw. Download a program like winmiter or tube miter.
I found this over at http://offroadfabnet.com a while ago. Its what I used to build my wifes bumper in the pic at the bottom.
"The chop saw method, if understood, is a science. With known tube size and joint angle, tube can be notched with great accuracy. The notch is achieved by cutting two opposing angles on one end of a piece of tube, to form a point. The cross-section of this cut will be an elliptical cut due to the shape of the tube. Changes in both of the two angled cuts must be made for the intersection angle and the size of the two tubes being joined. The only real limitation is the max angle of the chop saw.
You start with what I call the base angle. This is the angle of both cuts if the joint was 90*. For an example, I am fitting Two tubes together that are both 1.75", at an 90* joint. The base angle, or the angle of both cuts is 28*. These two cuts must meet at a point, and the point must also be centered on the tube. What if I want a 15* joint with my 1.75" tube???? You must start with your base angle, which was 28* for 1.75"(remember above), and subtract 15* from one cut, and add 15* to the other cut to form a perfect notch. So now I must make a 13* cut and an 43* cut with the point centered on the tube. Perfect coped joint, with no grinding. Remember your base angle will change with the tube being cut and the tube that you are fitting to.
Here are a few examples of base angles...
2.0" to 2.0" tube, base angle of 30*
1.75" to 1.75" tube, base angle of 28*
1.5" to 1.5" tube, base angle of 26*
1.25" to 1.25" tube, base angle of 22.5*
1" to 1" tube, Base angle of 20*
Now to fit different size tubes together
1.75" to 2" tube, base angle of 25*
1.75" to 1.25" tube, base angle of 45*
1.25" to 1.75 tube, base angle of 20*
1" to 2" tube, base angle of 12*"
I would add that for best results grind down any sharp edges so you aren't welding any thin edges.
I just use an angle grinder, though I hardly ever use round tube. There's a reason my control arms on the Jeep are square :thumb:
i'm going to pick up the harbor freight notcher, it'll work good enough for what I need. thanks for the help
I'm going up to Harbor Freight tonight after work Dave if you want to come, or we can take the Neon and I'll give you the 0.83 for the gas it will burn :thumb:
The notcher is on sale this week, I forget the price.
that sounds like a plan. What time are you getting off work today?
Around 4PM or so. Hopefully be back in time for the club meeting, but probably not.
I get off at work, can meet you at your place by 4:30. My plan is to make the meeting so if we go we won't be spending too much time there.
1 - 14 of 14 Posts
