Lumpy, you probably have the right answers but anyone can chime in here. Here's the situation. Driving my truck today it started shifting hard from 1st to 2nd, just a real abrupt shift. Then I was pulling onto the freeway and it wouldn't shift out of 2nd. Limped it to the nearest auto parts store and bought a quart of ATF. The dipstick showed a little low and after dumping in some more ATF the shifting is back to normal.
The tranny is a 4L80E in a 94 chevy 6.5 TD. Here's my questions, basically what should I do.
1. Drive it till it blows up then rebuild it? (Hoping it was just a little low on fluid and nothing was damaged)
2. Rebuild it now, and upgrade it to better pull my junk.
3. Drive it till it blows, and swap in a 4L85E.
4. Delete this post and offer it for sale on this website :rotfl:
Sounds to me like you were stuck in limp mode, most commonly caused by ignition switch, wiring, etc. If the trans gets fluctuations in power or a temporary failure, it will go into limp mode until the next drive cycle, or the next time you turn it on and off. Check the transmission codes in the pcm. I don't think the generic code readers will pull the trans codes, you need a scanner. If you have codes, fix those first.
Checked the codes and it threw 74, 85, and 87. I lost my login to TheDieselPage, but I'm pretty sure they are all transmssion codes. I'll know more when I get my new login info. Thanks for the heads up, hopefully I won't be needing a full rebuild.
