So my truck has 35s on it, and I think the manufacturer reccomends 32psi on the standard tires, but I am just curious what other people suggest. I put 35 psi in there and it seems to be doing good...
problem you may encounter is abnormal wear on the central tread with over inflation. A lot depends upon the pressure needed, weight of vehicle, tire itself and ride desired.
I run 35in BFG's with 35 psi. But my rig weighs 5600lbs and the rear is welded. The higher pressure doesn't scrub as much around corners.
