1 - 2 of 2 Posts
When I swapped the T-18 and put the Atlas behind it I replaced the output shaft to match the new input shaft for the atlas. In doing this, the tranny seems to be a lot tighter. The synchros don't seem to be working properly and when left in neutral it almost wants to crawl forward a bit. I think that the input shaft and the output shaft are push against each other so tight that it is causing this to happen and am wondering if time will smooth it all out or if I should pull it out and see what is happening. Anyone got an opinion?
1 - 2 of 2 Posts
