1 - 15 of 15 Posts
· Registered
can anybody tell whats wrong with this picture? these were on my front suspension
· Registered
dod you notice the length difference mike? One was on the driver side and the other was on the passenger side.
· Registered
no shit. One was in front of the axle, one was behind the axle, one has the top mount higher up the frame than the other and thats why it's longer.
Thats how they are stock and they are both the same amount of travel full extend to full compresion.
Nothing wrong with it.
· Registered
well that is news to me, I thought they were supposed to be the same length. Guess I need to do some more measuring before I get any new shocks
· Registered
Yeah definatlty. I have the same length of shocks on both sides but I used both rear mounts from the quad shock set-up so mounting locations are the same height. If you use the rear mounts they are a shorter shock and if you use the front the are longer. So whichever way you go you just need the mounts off of another truck. Try searching here if you cant find them local.
www.projectbronco.com
Mike
· Registered
I thought yall did that to get a better rti going forward :rotfl:
1 - 15 of 15 Posts
