Sandman said:
I have a dead 400 in my garage that I'm going to save the top end and trash the bottom end. Do you want the balancer?
What kind of shape is it in? Do you also have the flexplate?
I probably wont be doing anything to it until next summer. So far, its gonna cost me about $2700 to build it the way I want.
Here's a list of parts I plan to use, it's kinda hard to read because I copied it from a spreadsheet.
383 Stroker Parts List
Part Brand Part Number Store Price ($)
Balancing Automotive Machine 160.00
Camshaft Summit SUM-G5000 Summit 160.00
Crankshaft Scat 9,021.00 Scoggin Dickey 270.00
Flexplate Summit SUM-G101SFI Summit 56.50
Gasket, Head Set Felpro TCS45121 Auto Zone 7.50
Gasket, Oil Pan (1 piece) Felpro HS7733PT-2 Auto Zone 34.00
Gasket, Timing Cover Felpro OS34510T Auto Zone 26.00
Guideplates SDPC SD42355 Scoggin Dickey 14.50
Harmonic Balancer Dorman 594-016 Auto Zone 50.00
Head Bolts SR Torquer WRL-042660-1 (67) or WRL-042670-1 (76) Summit 760.00
Heads GM Perf. Parts 12495499 Scoggin Dickey 25.00
Install Pistons on Rods Automotive Machine
Main Bearings Clevite MS909P Auto Zone 20.00
Pistons Kieth Black KB100-030 Scoggin Dickey 208.00
Pushrods Comp Cams CCA-7812-16 Summit 30.00
Rings Childs & Albert RS9401-35 Scoggin Dickey 86.00
Rod Bearings Clevite CB663P Auto Zone 14.50
Rod Bolts ARP ARP134-6403 Scoggin Dickey 43.00
Roller Rocker Arms Comp Cams CC1301-16 Scoggin Dickey 276.00
TPI Setup Third Gen Resource 500.00
GRAND TOTAL 2,741.00
"REQUIRED" TOTAL 1,292.50
DIFFERENCE 1,448.50
