how do i go about getting the back bolt out of my leaf. im trying to take my driver side front leaf spring off and there is no place to put a wrench or socket on the bolt and the other is a nut do i just hit the hell out of it with a BFH OR WHAT?:confused:
You cant get an endwrench on the bolt? If you can, see if you can at least spin it around. If not, I've sawsalled them off before or like Lehi said, use a torch. I've gone through this and now those bolts get well greased whenever they are messed with.
Wait, what type of vehicle? It sounds like the toyota shackle to me, that one you have to remove the top nut and the bottom nut. the shackle will slide out then. The top and bottom bolts are pressed into the side plate on a toyota. Remove both nuts, then slide, beat, curse, etc, whatever it takes then.
no its round kinda weird i havent seen anything like it before i cant find my camera to take a pic so im just goin to have my buddy torch it off
