Okay I want some opionons here I will be getting the steel to build the rocker skids on the blazer what thickness should I go with. I know 1/4 is a good thickness but I am welding directly to the body. I want to know if anyone out there thinks that 1/8 or even .120 wall would work. These will be a permenant part of the body and I don't know if I can weld 1/4" thick steel to the probably 18 gauge steel properly Also these will have tubing welded onto them that will look like a regular rocker skid but the square stock will replace my rocker panels :rotfl: :rotfl:
