I HAVE AN 86 K5, I'N GOING TO BE TURNING IT INTO A ROCK CRAWLER. I'M GOING TO RUN THE BILSTEIN 9100 SERIES COILOVERS ON FRONT AND BACK,WITH 39.5 OR 44" CUT BOGGERS. MY DRIVETRAIN WILL BE 1 TON (DANA 60 FRONT,14 BOLT REAR) WITH HOPEFUL THE DOUBLER KIT FOR THE TRANSFERCASE. I JUST NEED YOUR GUYS HELP TO SEE IF I SHOULD EXTEND THE WHEEL BASE, WHAT GEARING, AND IF THAT SET UP SOUNDS GOOD, IF NOT WHAT TO CHANGE AND WHY.... THANKS
