1 - 2 of 2 Posts
I might be getting a set of 1 ton chevy axles 60 front and a 70 rr out of a 87 chevy. Has a set of M-715 5.84 gears out of a jeep that I can have too. I was told the M-715 rear dana 70 had a .500 pinion offset housing. The chevy has a .625 pinion offset. Can the M-715 gears be used in the chevy axles with a spacer and what are your thoughts on using spacers. Also will I be able to use the carriers from the m-715 and will they work if I use the spider gears from the chevy axles. Any help would be great thanks. Bart
1 - 2 of 2 Posts
