BRC ACTION ALERT
IDAHO ROADLESS PETITION NEEDS PRO-RECREATION COMMENTS
IMMEDIATE ACTION REQUESTED
Dear BRC members and supporters,
You may have read about the Idaho Roadless Petition in the newspapers lately. That's because despite all of the litigation and controversy of the "Roadless Rule," Idaho is pressing ahead with a plan on how to manage these lands.
Idaho has more roadless lands than any other state - 9.3 million acres. The Petition organizes these areas into management "themes": Wild Land Recreation, Primitive Areas, Backcountry Restoration and General Forest. The Idaho Petition's direction preserves recreation and uses as it now exists in current forest plans.
That's because Idaho's Roadless Petition was developed with full involvement with local user groups, counties and others who are impacted by this decision. It's a common sense proposal that, while protecting the undeveloped nature of Idaho's Roadless Areas, doesn't throw the baby out with the bathwater. It also protects a wide range of recreation, including motorized and mountain bike trail systems.
That makes it unique, and it also makes it worthy of our support. Please take a minute to offer your support of Idaho's Roadless plan by following the instructions below.
As always, if you have any comment or question, please do not hesitate to call.
Thanks,
Brian Hawthorne
BlueRibbon Coalition
208-237-1008 ext. 102
BRC ACTION ALERT:
IDAHO ROADLESS PETITION NEEDS COMMENTS
COMMENT DEADLINE MAY 10, 2007
SITUATION:
The State of Idaho's Petition for management of National Forest Inventoried Roadless Areas in Idaho (Idaho Petition) is beginning rulemaking. It is likely that the result of this process will LOCK IN management of our roadless areas for many years to come. It will dictate development of future forest plans and travel plans. It will give us certainty that our uses CAN continue to exist in these areas.
The final Idaho Petition rule will NOT make on-the-ground decisions about what road, trail or area is open. Future forest plans and travel plans will do that. The rule WILL provide the overarching framework for management direction and on-the-ground decisions.
Unlike some state Roadless Petitions, Idaho's does much to protect recreation and access. Public comment is needed to ensure this good proposal does not get hijacked by anti-recreation groups.
The Idaho Petition rulemaking is now in its Scoping Phase, which means the federal government is determining which issues will have to be addressed in the rulemaking process.
This whole process is on a VERY FAST TRACK (deadline for comment is May 10, 2007). For comments to be given full consideration, they need to be submitted ASAP!!!! We anticipate a Draft Environmental Impact Statement (DEIS) will be out by mid summer, 2007!
WHAT YOU NEED TO DO:
BRC is asking everyone to send an email comment letter today. Below are some comment suggestions you can use for your letter.
Send comments by e-mail to:
[email protected], or by snail mail to: Roadless Area Conservation-Idaho, P.O. Box 162909, Sacramento, CA 95816-2909.
COMMENT SUGGESTIONS:
It's best to start off with a brief sentence or two that tells about you, your family, your club and how you enjoy Idaho's Roadless Areas.
Tell the analysis team that you support the Idaho Roadless Petition as it is now written. Tell them that the Petition should be made into a permanent rule.
Tell the analysis team that recreational uses in Idaho's Roadless Areas are varied and valuable. Tell them you want to continue enjoying them as you have in the past.
Explain to the analysis team that you want Idaho's Roadless Areas to be well managed and you believe the Petition is a proper balance between protection and management. Tell the analysis team that you support the "General Forest, Grassland, Rangeland" designation. This wise management designation was specifically recommended to "provide a variety of goods and services, broad range of recreational opportunities including both motorized and non-motorized, while ensuring adequate flexibility to maintain forest, rangeland and/or grassland health." Tell the analysis team that you support this wise management designation.
Gives examples of any volunteer work and/or funding projects you've supported in Idaho's Roadless Areas.
Please be polite and make sure your email comment is sent by May 10, 2007. And tell all your friends and family to comment too!
BACKGROUND INFORMATION ON IDAHO'S ROADLESS PETITION:
INFORMATION FOR ADDITIONAL COMMENTS
The Idaho Roadless Petition manages Roadless Areas using the "theme" concept.
DESCRIPTION OF THEMES
1. Wild Land Recreation - 1.43M acres: These lands are now recommended for wilderness by the FS. Motorized travel is allowed, stating "preserves currently existing routes and class of vehicle further limitations subject to NF travel planning." No roads. Example: most of Ten Mile/Black Warrior in Boise NF.
a. WHAT THIS MEANS! We'll likely retain the trails and areas we now have, but no new ones. Use limited to what exists now. Trails and areas could be closed in forest or travel planning, but recreation opportunity should be retained.
b. IS THIS GOOD ENOUGH? If you're not satisfied, suggest better language when you comment.
2. Primitive Areas - 1.68M acres: "Managed to protect and maintain both the primitive character and accompanying primitive recreation opportunities. A variety of motorized and non-motorized recreation opportunities exist. Campsites may be visible at popular destinations and major trail heads or junctions. Recreation sites accommodate moderate use," motorized travel is, "Restricted to snowmobiles and motorized vehicles less than 50 inches, change in class of vehicle and designation of new routes is permissible subject to NF travel planning." No roads. Example: Most of Danskin & Smokey Mt. in Boise NF.
a. WHAT THIS MEANS! Camping is generally undeveloped and trail use is not heavy. New trails can be constructed and use can change, for example, to allow ATVs, subject to site-specific travel planning.
3. Backcountry/Restoration Areas - 5.5M acres: "Provide a variety of recreation areas while ensuring adequate flexibility to maintain forest health; these areas may be managed for summer and/or winter motorized recreation opportunities," Motorized travel, "General preference toward snowmobiles and motorized vehicles less than 50 inches; change in class of vehicle and designation of new routes is permissible subject to National Forest Travel Planning." Road construction/reconstruction is allowed, "with a preference toward temporary roads; however permanent road construction is permissible based on long term ecological need." Example: most of Deadwood in Boise NF, Mink Cr. In Caribou NF, and Garns Mt. in Targhee.
a. WHAT THIS MEANS! Camping is both developed and undeveloped. These areas contain our most developed trail systems.
4. General Forest, Grassland, Rangeland - .52M acres: Show increased levels of use while still retaining some roadless qualities. They will be managed to "provide a variety of goods and services, broad range of recreational opportunities including both motorized and non-motorized, while ensuring adequate flexibility to maintain forest, rangeland and/or grassland health." Motorized use is subject to travel plan, new temporary roads, but some permanent roads are compatible. Example: Acres that represent the "front country" and access points of our favorite roadless areas like 1116 acres of Ten Mile/Black Warrior in Boise NF, 2730 acres of Mink Cr. in Caribou NF. They're also sagebrush bench lands with the exception of most of Fall Cr.-Bear Cr. in the Targhee-Caribou NF.
a. WHAT THIS MEANS! It means that the greens are furious and are convinced that these acres will be paved over and developed. They're geared up to vigorously oppose these designations
b. YOU NEED TO SUPPORT THIS DESIGNATION! In general, it will allow maximum flexibility for improving and managing access to our favorite trails and areas.
YOU MUST LET ME KNOW IF YOU WANT A COMPLETE LIST OF ROADLESS AREAS AND THEIR ASSIGNED THEMES
YOU CAN ALSO COMMENT ON:
  • Do you agree with the assigned theme for your favorite roadless area? If not, which theme would your prefer and give detailed reasons why.
  • Did they miss anything? For example, the State Petition does not mention that Idaho's Roadless Areas contain many roads and sites important to Idaho's colorful history. You may want to expound on the importance of maintaining access to and interpreting these to preserve our heritage.
TRAIL MILES INFORMATION, BOTH MOTORIZED AND NON-MOTORIZED
% of Total
Trail USFS Trail
Area Miles Miles
Wildland 1,398 8.6%
Primitive 2,188 13.4%
Backcountry 5,386 33.0%
General 1,006 6.2%
Special 729 4.5%
Total Roadless Trail Miles 10,707 65.6%
Wilderness 4,207 25.8%
Trails in Roaded Areas 1,416 8.7%
Trails in Wilderness or
Roadless
14,914 91.3%
Overall USFS Trail Mileage 16,330 100.0%
ANY QUESTIONS? PLEASE E-MAIL OR CALL:
Adena Cook, Public Lands Consultant
[email protected]
Phone: 208-522-7339
I will get on this!
I will get on this!
Great! Thank you! :thumb:
The more comments we have on this, the better it will be for the Off-road community. Please feel free to copy & paste & email it out to your clubs, friends & family or whomever. We need all the support we can get. It will only take a few minutes of your time to make our voices be heard on this topic. You can email your comments in to: [email protected]
Also please take time to read the quick little background information on the roadless Theme areas. It will help you to formulate your comments.
The dead line is MAY 10th, 2007.:deal:
