i gotta do somethin with my steering. i am wonderin if a setup similar to a late 70's bronco would work on a k5, provided that i had a 2wd box. :banghead:
What front axle are you using? You can use a 2wd sector shaft, a jeep drop pitman arm and if you have the Dana 44 with the flat top knuckle, you are in good shape. You can buy the arms ready to go.
RUNNIN 1980 10 BOLT . I DONT HAVE THE PASS. FLATTOP NUCKLE SO I WAS THINKIN OF GOIN DOWN TO THE TIE ROD FROM MY 2WD BOX. I HAVENT LOOKED AT IT VERY CLOSELY SO I'M NOT SURE HOW THIS WOULD WORK.
