1 - 10 of 10 Posts
fullsize jeep cherokee parts
post up with what ya need.
Its going to the crusher...
we have parted 3 jeeps over the last year and have most parts.
You have 2 door cherokee parts? Do you have any door panels and arm rests? I'm not sure if the front doors on the 2 doors are different than the 4 doors or not so a 4 door door panel might work too.
edit: I could also use a rear window, upper weather stripping (the piece that goes in the top) and the regulator arm retainer clips if you have any of that stuff still.
Steve, I'll be heading out of here around 8 a.m. so I should be there around 9 or so. If that doesn't work let me know.
that should work good, ill be at the stage stop at 8, then prolly home around 9....
if anything changes call me 890-5454
Yeah they are the same, basically everything is the same, except the wagoneer has 2 extra doors, the chassis are the same, wheelbase and everything.
1 - 10 of 10 Posts
