1 - 19 of 19 Posts
Got the toy movable under its own power today, found out i hadnt welded on the spring perches in the rear, blew a u-joint and bent my quick fab rear d-line, got the rear axle centered under the toy better, 8 3/4" of tire outside the body, clutch rod connecting toy pedals to chevy clutch master isnt quite long enough, have to start in gear. And have a rear wheel seal leaking. All and all ITS ALIVE!!!
Now I can move it, and get it on a trailer to take to motorfest. Ill get some more pics soon.:thumb: :cool:
Discussion Starter · #2 ·
Driveline back in with replacement u-joint, made the clutch rod adjustable, now I can actually shift it.
finally after 2 years it moves under its own power....kinda weird this all happened because of a blown headgasket...lol
Hell yeah! I like it! I'll have to remember to weld my rear perches, I can see how easy that is to forget. Your rig is the C.R.A.P.:smokin:
toytech01 said:
Damn those things look wide compared to the Toy body.....
Looks good though!
Thanks I kinda like it too, other than its a pain to fit on trailers
Heres a pic, its ready for motorfest, well as ready as possible.
Lookin' good! See ya out there! :drive:
Oh I will let everyone know, but itll still be a while with the little stuff to finish. It might be a snow run the way things are going.
I fit the Burb on a trailer just fine, you just have too small of a trailer.
Discussion Starter · #14 ·
Yeah I just drive over the fenders, Its a borrowed trailer and it is really narrow, About 80" between the fenders, deck width is about 74". The toyota is 86" wide.
Discussion Starter · #15 ·
well for some reason I dont think it wants to be sold...
Moved it today, clutch let go, wont disengage all the way, and sounds like metal on metal grinding.
Discussion Starter · #16 ·
Well I didnt have a camera with me...
I hauled it down to foothill, used the forklift to flex it out.
Rear flex was 23" measured from the top of the tire to the body.
I didnt measure the flex in the front. But im guessing around 18"
It started to lift the driver rear tire when I had the pass rear tire about 43" off the ground. Not bad for leaf springs, but im not impressed yet.
Time to weld on the perches, so the rear quits moving when I flex and move on/off the trailer.
When thats done, I'll remove some leafs, and trim some more sheetmetal.
Well Im hoping it will be ready next summer now...
What's your frame heigth? What springs did you use? Are running a body lift as well? I couldn't tell from the pictures. It looks great!
Discussion Starter · #19 ·
frame sits at 27"
2" body lift
pro comp 6" lift front springs from 73-87 chevy
pro comp 5" lift rear springs from 88-98 chevy (63" long)
1 - 19 of 19 Posts
