I have read other threads on other sites about this, but what are your opinions? I want a hydroboost set up on my 72 Bronco (currently manual w/discs up front) and I have a heavy duty Saginaw pump. I also want to integrate a hydro assist steering ram. Will I need a remote resevoir pump? What kind of set up have you all seen work well?
I am a novice on this stuff, doing some research and want any info you have.
Thanks
I currently have hydroboost, and adding a hydro steering ram soon, Im just going to upgrade to an agr super pump...saginaw style pump.
I am going with a Hydro on my 67, but I don't have to worry about the hydraulic steering like you are doing. I am just adding the hydro out of a 79 Lincoln. I will post pics once it gets done.
I have hydroboost stock on my truck, and I don't think I would want to add it to something that didn't have it.
If you would bust a steering line on the trail and can't fix it, it would take out your steering AND brakes!
Goes back to the manual brakes I already have if my steering pump goes out.. Not that big of a deal. hydroboost is the way to go on the EB's, a ton of braking power when compared to the vacumn booster.
Okay I checked this out a little and it seems to make hydroboost work with hydro assist you have to get an AGR pump. I talked to a guy with this setup and he is using an AGR pump that has a flow rating of 3.4 gpm. He also has a big cooler and a remote resevoir for his pump.
Thanks for the tips. I will call you eric and get the details.
