im having issues with my 1998 dodge ram 1500 again:help:. whats happening now is that all of the sudden when im driving i hear a thud and then my truck dies has no power at all so i have to pull over and try to get it to start, it will not start if you keep cranking the key, the only way i can get it to restart is to disconect the battery and and then it will start up.
i am thinking it is the crank sensor since it loses spark when this happens....
anyone got some ideas?
sounds like the crank sensor deffinetly but to be sure if your check engine light stays on run to schucks or autozone they usually have a scanner theyll let people use in the parkin lot that should throw a code to tell exactly whats goin on.
