1 - 10 of 10 Posts
Yo, need your help experts! Whats the piece call on the ford where it holds the lights in place. I think it might be called a header panel but I dont know. Its the piece where you bolt the stock grille too. Here is a picture.
HELP ME!!!!!!!!!!!!!
I disagree. From my research, I found that the core support and the header panel were two different things. It goes grille and light, header panel, and then core support. Im guessing the core support has something to do with the radiator support.
THE CORE SUPPORT IS THE METAL PIECE THAT THE RAD MOUNTS TOO...
THE HEADER PANEL IS THE PLASTIC PIECE THAT SUPPORTS THE HEADLAMP AND ADJUSTERS.....THE GRILL ACTUALLY SCREWS TO THE HEADER PANEL :thumb:
1 - 10 of 10 Posts
