I redid my 93 Burb heads (5.7 TBI) Sep 01.... the head gaskets were leaking....
I replaced the cam, lifters, pushrods, rockers, springs, the whole can of worms and all was fine....but it still ran hot... found the radiator to be clogged after a while and replaced it..... no problems at all so I thought....
It did get to 250 for a short time but that was it... with the old rad in it ...AFTER all the replacement stuff...
now I find the head gaskets are leaking again and at a dramatic rate!!!! I lose almost 1/2 gallon of coolant in 300 miles!!! It does not run hot at all and no oil in water and no water in the oil... it's seeping out the block at the gaskets.... both side are showing runn-off down the block.
No loss of power is evident and all seems fine except for the leaks in the gaskets.....
I fear that with the rebuild of the top end and running the clogged radiator that it built up too much pressure and heat to blow the gaskets... is this a safe bet?
Now... am I safe to just replace the head gaskets and not worry about the heads or should I have them checked again.... I don't think he will charge me to check them...but not sure...
I just want this to be the LAST TIME I pull the heads on this motor....
I don't think a re-torque at this time will seal them up.....
