1 - 4 of 4 Posts
Well since Mac never seems to break when there are many poeple around I thought I would share this with the world. The unit hub bearings came apart, Mac busted a u joint on Wed night and upon my advice removed the axle shaft, well what seems to have happened is this exposed the unit bearing or caused it to become loose not having the axle shaft holding something or other in and the unit bearing split apart. Last pic is Pats rig doing its first recovery
You have to run at least the outer stub shaft of the axle or the unit bearing will do that. It has no support otherwise.
1 - 4 of 4 Posts
