1 - 10 of 10 Posts
84 K5 Blazer i tried starting it today and wouldent start i have a clear fuel filter and no fuel was getting to it....
i pulled out the fuel pump how do i tell if it is BAD or not??? any help would be apriciated....
:thumb: New pumps are like $20 for those... I'd just put a new one if you think it's bad.
thanks for the help Nate!!!
:thumb:
What you can do is put the pump back on put don't connect the line to the carb. Crank the engine over... it will pump out fuel if it's working. If not, either the pump is shot, or the line is plugged somewhere between the tank and the pump.
i put a new pump on bought it from NAPA instead of Checkers not going there for shit any more....
it works and is up and running.....
see, I'm right once in a while...:flipoff:
Yeah I don't buy stuff from Schmucks unless I absolutely have to.
AJ your Always right your a MAN....
that fuel pump was easyer then i thought and bonus it worked!!!
See told you so :thumb:
1 - 10 of 10 Posts
