i have 95 for with electronic aod. is there a transfer case that will bolt up to this to make it a right hand drive without buying a expensive adapter?
i have a toyota pikup with a 302 and an older aod trans divorced tranfer case. the truck that i have for the 351w fuel injection swap has a electronic aod with a left drive.
so is it driverside or passenger side drop?...which t-case do you have in it now, and would you be willing to part with it? also you could always narrow a d44 high pinion front or jut go full width. what about the possibility of using a conversion adapter, or doubling it up?
