Looks like its not as bad as I thought. I will still have to drop the gears and check all of the bearings but it looks like most everything survived the blowup.
This was the explosion on Upper Hell in Moab. The pinion nut decided to let go and the pinion gear went into the housing, my tie rod bent from the force of the ram, I lost my power steering belt along with the air pump, the radiator came loose, and the alternator bracket broke. I was also first in line. Yippee.
