1 - 9 of 9 Posts
DinoWagonMan!
On my dana 60 front, I was taking it apart, and on the spindle bolts, right before the brake bracket comes off, is a shim that is tapered...
one side is thicker than the other. it has many holes in it but it only fits 2 ways.
my question is this....I assume it helps/controls/sets caster, but the spot that each it fits is different on each side.
the drivers side puts the thin side at about 6 o clock..
the passenger side put the thin side at anout 12 or 1
which is correct??
I looked in all my books, and couldn't find anything on this.....
prolly an easy answer, but plz help....
What is the 60 out of??
DinoWagonMan!
dodge........90 is the vintage....cummings
I bought that one of A J's
Im not sure, but i think it depends on how much correction is needed, if a little more was needed on one side or the other they might have tilted it slightly to change the effects.
What's a Cummings?
Sandman said:
Its what happens when a group of male virgins go to the strip club for the first time. :thumb:
BWAHAHAHAHAHAHAHAH!!!!!!!!:rotfl::rotfl::rotfl:
that was teh funnay!
on a side note:
and Matt knows this how??? :flipoff:
80 percent of the time the thicker is at the top to compensate for axle "fatigue" those shim are to correct caster and camber -- somewhat...
I would put it in that way and take it down to the alignment shop for a checkup.................................
1 - 9 of 9 Posts
