1 - 12 of 12 Posts
I have dana 30 with 4.10 gears all stock shafts new brakes rotors
and chry. 8.25 with lockrite , 4.10 new brakes. lockrite has been to moab 2 trips works great . both are axels go cheap. :shocked:
I believe it is 29 spline but not 100% sure there off of a 94 cherokee.
The gears were pro. installed . no noise driving down the high way. I am in pinedale wyoming, it 150 miles from Idaho falls, but I travel to pocatello about every other week end. The front 30 I had to cut round buckets off to make my coils work on new axel. I can put something on if some one was to run coils. The rear has a 2" lift custom perch on it and the shock have been moved up. better ground clearences. And i put new seals in the rear this fall.
I do have the 15x10 rims that was on these axels. with 33" tsl on them 30% tread on 2 50% on 2. never any flats. If interested I'll work out a fair deal.
Damn.
I am tendering a deal on the XJ right now!
Arrgh!
Well, was gonna keep and build but they are so weak in stock form, and so much work to make tuff, and they don't really seat 6 and two dogs at well.
Besides Lehi's rig what Off-Roader does seat 6 and 2 dogs ? XJ aren't that hard to make tough enough for off roading either. Spendy yes, but it is possible. They are all spendy though when you start bangin them off rocks.
1 - 12 of 12 Posts
