1 - 10 of 10 Posts
· Registered
Well, I finished pulling the drive shafts out of the 77 Jimmy and went to change all the U-joints. The Rear driveshaft was a piece of cake, however, the Double-Cardan CV joint on the front suprised me: The U-joints did not have any locking rings on the CV joint itself! :shock:
Here's the question: Is this normal or has the PO just not fully seated the u-joint? Your thoughts or observations would be most appreciated. :mrgreen:
· Going Postal
Are the locking rings on the inside? I've seen that before. The rings go around the cup on the inside of the housing.
· Registered
Thats a good Question Sandman - I did not disassemble the CV joint to check - I just stopped where I was at (since it was getting dark anyway). I'll just pull this puppy apart this weekend and see where it leads. Thanks for the input....I'll check it out.
· Registered
Lucky for you I just did this very thing yesterday. From the factory, they used a plastic locking setup. You just have to press the caps until the plastic pins shear off. Then you can get them out like normal. I used a ball joint press and it worked great. Once you get the old ones out you just install the new joints and use the inside c-clips like normal.
· Registered
Well, I didn't pull them out yet but I took a good look at the setup - you guys hit it right on the head - it has the inside clips - can't say for sure if they're plastic or not but once it gets on the bench I'll know for sure!!
Thanks again!!
1 - 10 of 10 Posts
