Did you check all your mounts, tranny and motor????GateCity4x4 said:Went to fix the leak and found the top of the case broken! :angryfir:
Gonna be close for Moab. :angryfir:
Its all good. I think its related to the power output/ Tire size with the 4:11 gears that I used to run. I broke several transfer case adapters this last summer as well as blowing up a few drivelines. What I've done now is go to 5:13 gears wich should help unload the drivetrain some and I've added an extra mount off of the side of the transfere case over to the frame.fumes said:Did you check all your mounts, tranny and motor????GateCity4x4 said:Went to fix the leak and found the top of the case broken! :angryfir:
