1 - 4 of 4 Posts
· Registered
I'm just curious if the cab/body mounting locations are the same between these different years?
I finally got the CUCV yesterday, and want/need more cab room, for the up and coming family members. Since Chevy never made an ext. cab in the early years, I'm thinking about putting a mid-90's extended cab cab on the 1-ton chassis. I will be replacing the bed with a cage, so that is not a problem.
Thanks,
Dean
· Going Postal
I can measure the cab on my '92 1 ton after work for you.
The frames are different width's so I bet they are different. I bet you could do it though. Shouldnt be any worse then doing an S10 body swap.
1 - 4 of 4 Posts
