1 - 10 of 10 Posts
It's not my truck so don't start :mrgreen:
it is a 94 f-150 it has a new ac pump and is charged with no leaks but the pump keeps kicking on and off . with the truck turned off the ac pressure is high,but when i start it shows 25 on the gage, so i boosted it again and the pump worked fine for 5 min. then kicked on and off again.
sensers on the pump and the canister could they be bad?
they could be bad....or it could be a relay or premature AC clutch failure. The clutch kinda acts like a lock up torque converter...same principal...so no sensor working or only half way the pump only kicks on and off.....good luck with it tho.....btw stick to a chevy!!!! less advanced for you :finger:
O
knock knock is that a 460 ford , y yes it is. and do they all make that noise? why yes they do :finger:
Jump the presser sensor and see if the pump stays running after that. I had the same problem once and it was just the sensor.
thanks and have fun ths weekend in utah if u r going :thumb:
If ya still can't figure it out give Jeremy (TJeremy) a call at the shop. He's been doing A/C work for 13 years now & can probably tell ya what is going on. The number down there is 466-0812. :mrgreen:
Re: O
ASS........ :finger: thats what you call breaking them in properly whistle
Thx sabrina
Custom I think they come that way from the junk yard and when the dealers get them they do not let people test drive them you know. whistle
they mite not make it back. :firedevi:
have a nice day and thx for the help
1 - 10 of 10 Posts
