1 - 2 of 2 Posts
$6,000 1997 jeep tj wrangler sport, red with custom black bedliner, 4.0L engine with powerraid throttle body spacer, k&n air filter, dynomax after cat system, (exhaust manifold is not cracked), stock ax15 5 speed tranny, and 231 xfer case,dana 30 front, dana 35 rear, 4:10 gears, 3 custom lift, with 32x11.5 sigma rvt mud tires, (about 65% tread left), could fit 34 tires with the right rims...rims are powdercoated black stock rims, front swaybar disconnects....new radiator, new water pump, new serpentine belt, new alternator, new battery,new front seats, (no back seat), year old starter, year old throttle position sensor, year old fuel sending unit/fuel pump, year old top and window, (two sets of widows are included, one in mint condition, the other has been slit open in a break in)full hard doors, interior painted black with bed liner, could use touched up(see pictures), floors are rust free and bedlined in black, no passenger air bag, (its storage space now), driver air bag has been disconected, no clutch safety lock, (you can start it without the clutch pedal depressed)......this jeep runs perfectly and has been very reliable since i acquired it...it has 143,000 miles on it but should be good for a few hundred thousand more.... no mechanical problems....it also has some rust coming through the fenders (see pictures),and some mud/surface rust on the frame(but no rot) no other real rust problems, some scratches due to tree limbs and such...the snorkel in the photos has been removed due to it getting caught on tree limbs, but has been repaired and will be included...also has a jerrycan mount with jerrycan in the back....a dome light mounted to the roll bar, fog lights up front, and a BRIGHT backup light...the stereo is a cheap walmart cassette deck, but it works, front speakers are good pioneers, rears are home stereo speakers...heater works great....Located in Columbus, Ohio....let me know if you need any more info. pictures at:
jeep call or email anytime (614)316-0819
[email protected]
-Josh
1 - 2 of 2 Posts
