1 - 6 of 6 Posts
what is the difference between an electric 700r4 and a non electric one.and can you make an electric one non electric...if that makes since... i want to put one in my 82 fullsize chevy. its out of an 86 suburban. thanks in advance!
-ray
Do it. All plugs work the same functions, even though inside there are different wiring harnesses. You can put a newer one in an older one, but not always can you swap an older one in a newer one.
ok...i put the 700r4 in my truck and i got some problems... it slams into gear really hard. vibrates once you get past 25. i checked the oil and its good...its not in 4 low. and im out of thoughts. anybody got any idea?
I'm sure Chris can help you out. Bowman Transmission and Offroad 599-1050
thanks ill give him a call. i figured out the vibrating was my fault.. didnt get the driveshaft tight. im still confused about the tv cable so ill give chris a call this week. thanks for the help!
1 - 6 of 6 Posts
