1 - 20 of 35 Posts
More parts from my early Bronco teardown:
Summit fuel cell
aluminum
20 gallon capacity
21x24x11 inches
foam filled
fuel sender for '67-76 Bronco (14 ohm full, 79 ohm empty)
$125
Tuffy Series II center console
8x12x24 inches with cup tray 8x12x20 without
black
$50
DUI conversion distributor for Ford smallblack
p/n 31820
Ford 221-289-302
$100
Flaming River Tilt Steering Column
large double on steering shaft end
GM splines on steering wheel end
$50
'66-76 Ford Bronco Hood
OEM steel
black
$150
'66-76 Ford Canvas Top with Doors
Kayline top
custom doors with zip out windows
doors do not require fiberglass inserts
doors extend only to lower hinge (this gives a lot of room for trimming the rocker panels)
$50
'66-77 Ford Bronco 5 1/2" lift leaf springs
$50
Edelbrock Performer Manifold for Ford smallblock V8
$50
4.56:1 standard rotation D44 R&P
new in box
$50
Currie Johnny Joints
new
p/n CE-9112
2" Johnny Joint with Greasable Bolt
total of 8
$20 each
I'll take that center console from ya. PM me with details on when/where we can meet.
damnit damnit damnit - I knew I should have logged on last night.
Pete,
If the center console or column fall through, I will take them. Can you post some pics of the soft top/door combo? I am most interested in the soft doors, since I do have a new Bestop already, but I will buy the package so that you don't have pieces laying around.
Any other bronco parts that you are gonna tear off?
thanks,
dan
Just an FYI. The summit fuel cell is actually made by RCI. They are just put in a box with a summit part number on it.
I'll take the johnny joints if you still have them.
Where are you located and i could come and get them from you sometime tomorrow.
-Andy
I should have read a little closer as I want soft doors that will work with my inserts. Sorry.
Please do let me know if the column or center console falls through.
thanks,
dan
this is starting to piss me off! I am missing all the stuff I want. Ahhhhhh
could I see some pics of the hood. Also what kind of shape are the rear leafs in? Wish I would have seen this sooner and had a little more money to spend.
Do you have anything you need for your rebuild Pete? I believe several of us have been doing a bunch of different conversions and probably have parts laying around if you need them. I know I have a bunch that are just taking up space.
interrested in pics of the hood as well.
Would the 4.56 gears work in my 1990 F-150 front end? It is a TTB Dana 44.
1 - 20 of 35 Posts
