1 - 4 of 4 Posts
I am new to the 4X4 culture and would like some help regarding my vehicle. I have a 2000 Chevy Silverado LS 4X4 short bed single cab with a 6 inch suspension lift manual trans. My question is how do I choose the appropriate anti sway bar for my application? ( I would like a front and rear set up) )
Does it make any differance if the vehicle has been liftted or not?
Also does anyone know what clutch kit I can use with my application?
What brand of lift kit do you have, and what problems is it causing that you feel you need a swaybar?
all 1988 to current IFS chevy's will have a front factory anti-sway bar....unless some tool decided to leave it off when they lifted it.....
Discussion Starter · #4 · (Edited)
procomp explorer series suspension lift kit ( 6")
The reason being that I feel that the vehicle is really unstable on corners especially when I go offroad.
I asked around and did a little research on the side and found that the propable solution to the problem is an anti-sway bar set up.
1 - 4 of 4 Posts
