1 - 2 of 2 Posts
Hey guys I had a few questions. I want to do a simple 2 inch lift on my 93 ranger and I dont want to spend that much money. My plan was to get some coil spring spacers and blocks for the rear leaf springs. I can get both for 2" but my question is, will the stock shocks work? Also somebody left a review about the spacer and says you will need a 2" drop bracket. Were can I find that drop bracket?
And yes I will also be putting some spacers behind my wheels and getting my truck slightly wider also. 1.7 inches each side to be exact.
you don't need the brackets for 2", but over 2" you will. if you want the bracket you can find them at jcwhiteny or a place like that. stock shocks will work but will limit flex. it already has a block in the rear if it's 4x4, not if it's 2wd. go with belltech 6400 shackles they are 2" lowering shackles for a 88-98 chevy c1500, but it will give you 1.5" of lift in the rear and flex.
1 - 2 of 2 Posts
