Tire balancing with bbs or air soft pellets? - Planet 4x4
Go Back   Planet 4x4 > 4x4 Discussions > General 4x4 Talk
General 4x4 Talk For all Offroaders
Reply
Thread Tools Display Modes
Old 08-24-2009, 02:45 PM   #1
4whlflop
4whlflop's Avatar
So has anyone on here used bbs or air soft pellets to balance out tires? I was wondering how this works. It seems the airsoft pellets/bbs would be much quieter than the steel bbs. I just wonder how many ounces of bbs one would have to put in to balance a tire?
4whlflop is offline   Reply With Quote
Join Planet4x4! It's Free!
Join Planet4x4 For Free! If this is your first visit to Planet4x4 please take the time to join us .
Registering is required for you to post on the forums. Joining us will also give you the ability to track messages of interest, send private messages to other users, search our forums, view attachments, and take advantage of the many other contents of Planet4x4.net! It's free and takes just a few seconds to complete.
Click here to join our community!
If you are already a member of Planet4x4, please login above to gain full access to the site.
Sponsored Links
Advertisement
Old 08-24-2009, 03:00 PM   #2
Chevycrew
911 and RescueModerator
Chevycrew's Avatar
Re: Tire balancing with bbs or air soft pellets?
We have tried it, we ran 2000 of the heavy airsoft bb's in one tire. They seems to work well.
I have since quit worrying, and quit balancing tires.
bb's, regardless of the material dont make any sound unless you are starting or stopping.
Chevycrew is offline   Reply With Quote
Old 08-24-2009, 03:08 PM   #3
Redmist
Redmist's Avatar
I have two of my 40" Iroks filled with Airsoft BB's, and two without..
Other then the noise of the BB's splashing around inside coming to a stop, I have yet to notice any difference in any tires...
I don't think I will ever do it again, and I drive my jeep on the road alot!!
Redmist is offline   Reply With Quote
Old 08-24-2009, 03:24 PM   #4
Larry
I just had tires put on my RV and they used this http://www.imiproducts.com/equal/installation.aspx
I don't see why it wouldn't work in a wheelin rig. Seems it would keep up with the tire chunking that always throws off balance.
Larry is offline   Reply With Quote
Old 08-24-2009, 04:23 PM   #5
WOOD
is ANI-FACEBOOK!
WOOD's Avatar
I've heard of people using steel bb's, plastic bb's, equal, and dyna beads. I have heard that steel bb's can rust, and Equal can clump. I have not heard any bad info on airsoft style plastic bb's. I have heard that dynabeads have many benefits but is expensive and if plugs get used they stick to the plug.
IMO I would try something cheap like airsoft beads.
Here is a link to dyna beads. http://www.innovativebalancing.com/
WOOD is offline   Reply With Quote
Old 08-24-2009, 04:26 PM   #6
Chevycrew
Chevycrew's Avatar
the dyna bead chart is what we used to figure out how many bb's to use.
Old 08-24-2009, 04:28 PM   #7
RCKSQRL
Pimping the ride
911 and Rescue
RCKSQRL's Avatar
I have regular bb's in mine. do they work... well it seems to do ok however I can not compare to without. honestly, they make a cool sound when coming to a stop! That is all I can say for them.....
__________________
"Rolling" the one and only
4Krawler
RCKSQRL is offline   Reply With Quote
Old 08-24-2009, 04:32 PM   #8
WOOD
is ANI-FACEBOOK!
WOOD's Avatar
That is my plan when I get to it. Then use Airsoft pellets. They are much cheaper.
Old 08-24-2009, 09:08 PM   #9
cmoore
Riding Shotgun
cmoore's Avatar
6 ounces of airsofts in each of my 39.5 bias iroks. they run smooth as glass at 75. I'm happy.
cmoore is offline   Reply With Quote
Old 08-24-2009, 10:21 PM   #10
Tumbleweed
Tumbleweed's Avatar
I had 7 or 8 oz. in each of the 37's on the Toy-worked awesome.
Airsofts.
Tumbleweed is offline   Reply With Quote
Old 08-24-2009, 11:11 PM   #11
Custom
I kill 460's
Custom's Avatar
golf balls
Custom is offline   Reply With Quote
Old 08-24-2009, 11:42 PM   #12
Chevycrew
Chevycrew's Avatar
Originally Posted by Custom View Post
golf balls
Why not just drop in a baseball or two?
Old 08-25-2009, 12:24 AM   #13
4whlflop
4whlflop's Avatar
I will give it a try for shits and giggles.
Chevycrew: You could probably fit a bowling ball in those michelins.
Old 08-25-2009, 07:08 AM   #14
RCKSQRL
Pimping the ride
911 and Rescue
RCKSQRL's Avatar
just think, weights down low so......
__________________
4Krawler
Old 08-26-2009, 08:27 AM   #15
The Torch
The Torch's Avatar
I'd never heard about doing this... so I'm curious. What keeps the weight from building up at one point and throwing everything off-balence?? What is the theory behind this?
And why wouldn't some sort of liquid work? Water might be too corrosive, and oils might break down the rubber, but if something else were found that had the consistency of, say, Maple Suryp... would that do the same thing and be silent too?
(Or just invest in enough Slim and let it do double duty... sealing small punctures and creating a self-adjusting balance) LOL.
The Torch is offline   Reply With Quote
Old 08-26-2009, 08:30 AM   #16
Chevycrew
Chevycrew's Avatar
You can use a liquid, there is stuff out there for balancing and sealing punctures.
I think there is a big explaination of how it all works on the dyna beads website.
Old 08-26-2009, 08:36 AM   #17
landtortise89
landtortise89's Avatar
a guy on another board had them in his 40" boggers and ran them up to 80 mph with out any vibes. They are supposed to make you tires last longer.
landtortise89 is offline   Reply With Quote
Old 08-26-2009, 09:37 AM   #18
4whlflop
4whlflop's Avatar
A viscous fluid will take time to flow into the area that needs the weight . Think winter and maple syrup, yummy!! Water freezes. The bbs distribute themselves as soon as you get rolling. There is a sort of powder, I think called equalize, that is used but it is messy and can clump up. I guess if you got some moisture in the tire, the bbs could also stick together and clump. But they should break apart and balance out. Slime will help with the punctures but it coats the inner tire. It may help with the balance, although it is pretty thick.
I am going to go get some today and will try to get them in the tire before the weekend. We will see if I can break the bead off the rims to get them installed. Maybe they will make enough noise to drown out the sound of my square driveshaft clanking.
Old 08-26-2009, 07:38 PM   #19
ibjeepn
ibjeepn's Avatar
I had Les Schwab put in "equal" they have a machine that just shoots it in through the valve stem. No muss no fuss and you can tell them how much you want based on the size of the tire (they have a chart too). It is actually made for this use, unlike bb's which are made for shooting - stuff.
jT
ibjeepn is offline   Reply With Quote
Old 08-26-2009, 07:55 PM   #20
Tumbleweed
Tumbleweed's Avatar
If you use Equal, you do have to change the valvestem core to one that won't let the Equal plug it up. Les Schwab will change these for you.
We have tried Equal on our mixer tires with little success.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
